Topic: Gemini G2v Can only Scratch on 1 deck. Help Please!
Hello fellow Dj's ran into a a lil problem. I cannot scratch on both decks on my Gemini G2v controller. The left deck works perfect. I can scratch and search by turning jog wheel. Right deck I can only search and cannot scratch. I checked all settings, controller is on Vinyl mode. The jog wheel itself does work because if I pause a track and scratch I can hear the scratch, but when the track is played its like the scratch effect is muted. I reinstalled VDJ8, controller driver, and did the latest update on controller. Did not fix my issue. Any help would be appreciated. Thank You!
geposted Mon 31 Oct 16 @ 6:59 am
