Forum: Addons
Topic: Virtual Lite
geposted Mon 31 Oct 16 @ 4:50 pm
I just tried your skin, and discovered that the browser zoom mode does not work correctly.
This is the result (above the browser)......
geposted Sun 06 Nov 16 @ 10:35 am
Repaired browser zoom, check it...
geposted Mon 07 Nov 16 @ 9:51 pm
@DjKaos2012
Keep in mind that the updates of the Addons still go through the same review and approval process, just like the first submissions.
I made your update quickly approved, so keep that in mind for the next ;)
Also, when you submit an update, please add a Comment with a short description on what has been changed, in order to speed up the process.
geposted Wed 09 Nov 16 @ 10:26 pm
AsTheDJPRO InfinityMember since 2008
+1
geposted Thu 10 Nov 16 @ 2:47 am
I see two decks but is 3 playing? & I don'e see 3 & 4 decks
geposted Thu 10 Nov 16 @ 9:23 pm
Yes, I just came to post the same thing. It's related to the other issue.
In the browser zoom mode you see four decks, and that's where you notice three of them are "playing" when only one should be.
It's supposed to be a two deck skin. Why is there code for four decks?
geposted Sat 12 Nov 16 @ 9:09 am
bump
geposted Sat 19 Nov 16 @ 10:52 am
is there a way for you to make is a 1366x768 resolution for virtual dj 8 or how can i change the resolution . thats the highest resolution on my laptop help please
geposted Sat 08 Jul 17 @ 9:52 pm
hola mi gente quiero que me ayuden con un codigo licen controladora ergo v
geposted Mon 01 Aug 22 @ 5:27 pm
