Topic: Recording static?
Hey friends! So I just switched to vdj8 from vdj7, every time I try to record a set the recording comes back just static nonsense? Any input? Any help? Thank you ahead of time
geposted Fri 04 Nov 16 @ 12:02 am
what gear/hardware are you using and how are those connected ?
What is the Audio setup of VirtualDJ (screenshot) ?
geposted Fri 04 Nov 16 @ 4:09 pm
I have a numark ns6 connected to a pc via USB, that's the only connection tho thank you for the help in advance
geposted Sat 05 Nov 16 @ 12:32 am
Delete the "record" line from the Audio setup and click to APPLY. Try to record again.
Use the"record" line only if you send Master to the NS6 sound card (which is not the case in your current Audio setup)
geposted Sat 05 Nov 16 @ 1:15 am
Fixed it man thanks a lot ☺️
geposted Sat 05 Nov 16 @ 11:51 pm
