Hi there, is there a proper VDJ scripting command list / manual, with explanatory syntax per command?
All l've found is: http://www.virtualdj.com/wiki/VDJ8script.html
(and related links at bottom of that page)
Also, there is the categorised list of action commands in the Virtual DJ "Controllers" window (haven't checked the plugins section but doubtless more commands are there too). Thing is, there is rarely any syntax info attached to those commands, and l'm pretty sure some commands are not on the list.
Strangely, the "Documentation" link on the Controllers window links to .... the above-mentioned "VDJ8script.html" page. Weird, because the Controllers window has a zillion times more info than that link.
geposted Mon 07 Nov 16 @ 11:24 pm
I had to get this via Google, l couldn't find any pages within the current VirtualDJ website linking to it:
https://www.virtualdj.com/wiki/VDJscript_verbs.html
https://www.virtualdj.com/wiki/VDJscript_verbs_v8.html
At least you get the actions, not much syntax though.
geposted Tue 08 Nov 16 @ 3:02 am
And yes, it's probably the exact same info as in Virtual DJ's "Controllers" settings section.
geposted Tue 08 Nov 16 @ 4:35 am
Other than the link on this page, in the "verbs" section
geposted Tue 08 Nov 16 @ 11:03 am
