Topic: Variable BPM accuracy & Sampler in sync-lock mode
Hi, I've found a problem with variable BPM tracks...
Can you please correct this problem? I've done more than 400 variable BPM track analysis and most of the time i can't use the sampler anymore to re-style the music.
Conditions : When then end of a beat-grid (4th black beat in the example) is not perfectly matching the start of a new variable beat grid [1st beat grid after the red Variable BPM anchor].
Problem : Sampler in sync-lock mode totally lose synchronisation.
If last beat ends very precisely when new variable beat anchor starts the problem doesn't occur but this accuracy is very very hard to be found.
In this example, the sampler stays sync.
I would like sampler (in sync -lock mode) to stay synchronised to new beat anchor even if a new variable beat grid anchor doesn't perfectly match the end of the previous one.
Thanks for your help time and support.
geposted Tue 08 Nov 16 @ 12:05 pm
