Forum: VirtualDJ 8.1 Technical Support
Topic: PITCH AND AUTOMIX
When playing a playlist on automix and pitched to e.g. 7%, the pitch drops automaticly back to 0% when moving on the the next track. That's annoying. How do i avoid this?
geposted Fri 11 Nov 16 @ 1:13 pm
Hi Tim
what do you want to achieve?
There is a way of keeping the pitch level as set by the user, I'll try and find the script.
best ray
geposted Fri 11 Nov 16 @ 1:27 pm
Ok, so here's the script to maintain the pitch durind AM
var_equal "AMpWA" 0 ? off & set "AMpWA" 1 & repeat_start_instant "AMpitcher" 33ms & load_pulse ? repeat_start_instant "pitchRem" 1000ms 1 & pitch & param_cast & set "AMpitch" : get_var "AMpitch" & param_cast & pitch : blink & set "AMpWA" 0 & repeat_stop "AMpitcher"
Just put it onto a custom button.
and here's the thread that got it all going
http://www.virtualdj.com/forums/201088/General_Discussion/Automix_Compared_to_VDJ7_and_VDJ8.html?search=jiver&page=1
hope that helps
ray
geposted Fri 11 Nov 16 @ 1:36 pm
Where do i put this script?
geposted Fri 11 Nov 16 @ 2:16 pm
can you explain this custom button?
geposted Fri 11 Nov 16 @ 2:21 pm
This is one of mine
A variable for on or off, currently off [ = 0] make the off [not lit up] switch the variable on
I have covered this indepth HERE it watches for a new track to be loaded
new track not loaded every second get the current pitch and use that value to set a variable
new track loaded getthevalue ofthe variable and set the pitch with it
this bit is the reply to the firsts query is the variable on, yes currently, blink the light, we have pressed the button while on turn the variable off and stop the repeating script
geposted Fri 11 Nov 16 @ 3:26 pm
Thanks found it and it works... (Y)
geposted Fri 11 Nov 16 @ 7:07 pm
geposted Fri 11 Nov 16 @ 8:43 pm
