Hello. I use virtual dj version 3311 and a pioneer ddj-sx and i have a 2 problem.
First problem is in deck with volume fader zero. If i touch the needle search left or right, load song select in deck left or right. And if i move the position od song with shift+needle search the audio of other side is affected with this movement. If volume zero is present, if i touch the needle search, the song position move without press shift.
The 2nd problem is in plates scratch. if i move in vinyl mode or jog mode the plate to init song, and scratch the plate, the other song stop and affect the sound out.
I tested version
virtualdj pc v8.2.3343
virtualdj pc v8.2.3420
virtualdj pc v8.2.3432
virtualdj pc v8.2.3440
virtualdj pc v8.2.3456
virtualdj pc v8.2.3471
virtualdj pc v8.2.3512
virtualdj pc v8.2.3514
and dont work fine in this versions.
Please! fix this! Thank you!
Windows 10 64 bit. AMD A8 Quad-Core 2.5 Asus / ATI 2GB / 16GB RAM / SO in disk 120 Gb SSD / Pioneer ddj-sx
I tested version
geposted Sun 13 Nov 16 @ 7:15 pm
Could you please describe your issues a little better ?
From what I think you're trying to say it seems that your sound settings are wrong. On the other hand I can't really understand what you're saying...
geposted Mon 14 Nov 16 @ 12:03 pm
