Hi,
It seems that database.xml file contains POIs (automatic or manually defined via the POI editor) infos on songs stored on this drive.
If I copy songs to another drive (that eventually has its own database.xml file), does it update the destination database.xml file with the new songs infos ???
Regards
Regards
geposted Wed 16 Nov 16 @ 5:58 pm
If you perform the copy from inside vdj then yes it will.
geposted Wed 16 Nov 16 @ 6:06 pm
I use a folder sync program from my main hard drive to a backup drive all the time and all info is transferred from one drive to another.
geposted Wed 16 Nov 16 @ 10:29 pm
