Hey there,
I have a problem with prelistening in the Track Editor since the last 3 or 4 builds, if I use the internal Soundcard (WASAPI-Mode) of my PC (Win 7).
If I start Playback there (Button or double click), Track Editor asks about using MasterOut because of missing HeadphoneOut, but nothing happens then.
Does anyone has this problem, too ?
Regards
Michael
Regards
Michael
geposted Thu 17 Nov 16 @ 11:07 am
At first I thought I can confirm, but now it is working.
Make sure your Audio setup is correct. Mine is set to Speakers only, internal soundcard, wasapi.
Restart VDJ. Now it should work.
geposted Thu 17 Nov 16 @ 4:34 pm
Mine is set as yours, too.
Tried it again. Works with build 3493, but with build 3514 it doesn't - not with Audio- and not with Video-Files.
Realised one more problem at this machine:
Prelisten doesn't works with Tracks, which are edited with the Track-Editor.
geposted Fri 18 Nov 16 @ 8:13 am
all ok with 3517
geposted Fri 18 Nov 16 @ 8:21 am
Yes, my test version was 3517 too.
geposted Fri 18 Nov 16 @ 8:23 am
Okay - tried it now with build 3517. Didn't saw, there was an update to it from 3514.
It seems to be fixed now and it works !!!
geposted Fri 18 Nov 16 @ 10:25 am
