Forum: VirtualDJ Skins
Topic: Skin Builder - Page: 6
Can this create "VIDEO" skins, like for broadcasting??
In theory, any skin created with Skin Builder and Extractor can be used as a Video skin, by just moving the generated zip skin file from /Skins to /VideoSkins folder.
But there are some things that will need manual modification, like removing the logo, min, max,close buttons and probably add some elements not available in Skin Builder
Ok, Thanks for the info. Hopefully we can get this setup in a future update??
Is there any way to add a panel without cloning or mirroring? I want to manually add panels to the same side of the screen, but there's no way.
For some reason, i tried to use the skin builder extractor but it always doesn't work because it keeps saying that i used 0 modules even though i used tons of modules. Can it be fixed?
