My playlist use to save in "alphabetical order". Now when I create a new playlist and save it, the new playlist shows up at the very bottom of all the other play lists.
Any suggestions on how I get it to save in alphabetical order again?
Thanks - Todd
Thanks - Todd
geposted Tue 29 Nov 16 @ 2:45 am
right click the playlists root folder and "reset sort order"
geposted Tue 29 Nov 16 @ 8:45 am
Thank you for your response. That option is NOT available.
geposted Tue 29 Nov 16 @ 9:15 pm
(switched to my regular account)
I can sort a play list in the browser section(song list area) but that is NOT what I am trying to do. What I am describing is for the folder list area under the PLAYLISTS FOLDER.
Hope that clarifies things. Thank again for the response.
geposted Tue 29 Nov 16 @ 10:03 pm
I have a guess, but it is just that.
In your VDJ documents folder, look under PLAYLISTS where all of them are listed. If there is an item called "order", delete it.
In the VDJ8 folder structures, I've learned that if there is an "order" file, it allows you to define an order other than alpha.
Delete it, reverts to alpha.
Hope that helps..
Hope that helps..
geposted Wed 21 Dec 16 @ 4:27 pm
