Topic: Strange behavior in,i guess, v b3523
labbedjPRO InfinityMember since 2013
Today I had lots of problems with the software. 2 crashes in less than 5 hours. Program closed and reopened on another icon as if it was twice on the dock. Cueing deck A made irregular playback on deck B. Both decks, not at the same time, where not loading songs I know are ok. Lots of bad graphics on the screen as you can see this is one picture I took. Trouble on top bar, crossfader play buttons and hotcues buttons, effects, browser,volume graphics bar and all over the folders and songs. Everywhere. I use default interface now to avoid this problems but, today did not helped. Re-installing the interface solve the problem a bit. I wouldn't mind too much if i knew the cause and there where no crashes (5 second crash) and reopening with options reseted.( font small, covers again.) VDJ 8.2 b3523
geposted Sat 03 Dec 16 @ 6:55 pm
