Topic: Delete a file with one keystroke?
I'd like to be able to delete a highlighted song (from the database AND hard drive) with just one keystroke instead of the 2-step right click file operations -> delete. Is there a way to do this?
geposted Tue 06 Dec 16 @ 1:46 am
Not possible, nor likely to be directly via script.
Assuming you are previewing tracks and will be deleting several
time saving work around is to colour unwanted tracks a distinct colour, set up a filter folder to get tracks of that colour and then you can select them all from there and delete in one go.
My blog "lazy sunday script" covers this a little but Pachn has a better blog, you'll find a link on my wall.
Also application key then F then D then Enter to delete tracks is a bit less strain on the wrists compared to mouse work.
geposted Tue 06 Dec 16 @ 2:39 am
Yes, once you get used to it, the "color tracks before deleting" method is acutally a very elegant method.
geposted Tue 06 Dec 16 @ 12:55 pm
Thanks.... That color/filter idea is a good one... never would have thought of that.
geposted Tue 06 Dec 16 @ 5:15 pm
