Topic: Reloop rmp3 alpha MK2 wrong midi identification
I tried to connect two Reloop RMP 3 alpha with virtualdj v8.2.
Reloop RMP3 Alpha version MK1 work fine.
Reloop RMP3 Alpha version MK2 is identified from virtualdj as a RMP2.5
Midi commad are completly wrong.
Thanks in advance
geposted Tue 06 Dec 16 @ 11:38 am
Not familiar with the MKx versions of the RMP3
http://www.reloop.com/catalogsearch/result/?q=rmp-3
There is a strong possibility the "MK2" to be a unit not supported natively, and the detection could be faulty based on a similar sysex ID (instead of the safer VID/PID)
Out of curiosity and just to see how it's detected, please try the following.
- Open VDJ 8, goto Settings->OPTIONS
- Search for the setting CreateMidiLog and set it to Yes.
- Close VDJ.
- Make sure the RMP3 MKII is connected
- Open VDJ.
- Close again.
- Post here the content of the Log Report.txt file you will find in Documents/VirtualDJ folder
Hi,
content of the Log Report.txt:
--- 2016/12/08 - 12:40 (3523)
Audio device found: name="Realtek Digital Output (Realtek High Definition Audio)" vid="0x10EC" pid="0x0663" hardwareID:"{0.0.0.00000000}.{3144c1a8-1203-4224-8c89-fcd447126f15}"
Audio device found: name="Altoparlanti (Realtek High Definition Audio)" vid="0x10EC" pid="0x0663" hardwareID:"{0.0.0.00000000}.{8fa5436b-f65b-408d-8129-3a2047251610}"
Audio device found: input name="Realtek High Definition Audio" vid="0x10EC" pid="0x0663" hardwareID:"{0.0.1.00000000}.{4f4c90d1-88c1-407c-ad47-c3a97aa92e6d}"
Audio device found: asio="ASIO POD HD500X" hardwareID:"0DAA6557-319B-43B9-A58C6E25DDEB7C96"
Audio device found: asio="PIONEER DDJ-SZ ASIO" hardwareID:"DF09375C-4AED-4805-8170AF9C56449D40"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_200c&pid_0016&mi_00#6&189b7406&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_200c&pid_0016&mi_00#6&189b7406&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global : Reloop RMP-2.5a
Assigned Reloop RMP-2.5a, type:2, index:1
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
[12:40] Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
HID Device found: VID:0x046D PID:0xC52F path:\\?\hid#vid_046d&pid_c52f&mi_01&col03#7&72cef8f&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x0000 PID:0x0000 path:\\?\hid#atk4001#3&37c1d7c8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x046D PID:0xC52F path:\\?\hid#vid_046d&pid_c52f&mi_01&col01#7&72cef8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
HID Device found: VID:0x046D PID:0xC52F path:\\?\hid#vid_046d&pid_c52f&mi_01&col02#7&72cef8f&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
[12:40] Midi In Closed (\\?\usb#vid_200c&pid_0016&mi_00#6&189b7406&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
[12:40] Midi Out Closed (\\?\usb#vid_200c&pid_0016&mi_00#6&189b7406&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
Thanks in advance
Stefano
VID/PID 0x200/0x0016 are indeed the Hardware identifiers of the RMP2.5a, so VDJ correctly detects the unit as such. Ideally, if the unit you have is a different model (with different MIDI messages or/and layout), it should have it's own unique identifiers so that we could add support for that unit as well.
Will contact Reloop and find out more.
It's very strange, this RMP3 MK2 work fine in other softwares.
Is it possible fix the problem with a midi custom configuration?
I also exposed the problem to the Reloop support, I'm waiting for an answer
Thanks in advance
Stefano
