Topic: Audio Problem for VDJ 8 MAC
I currently have a problem with either Virtual DJ or my DJIO. When I set my audio to internal soundcard, Channel 1&2: Master, Channel 1&2 headphones, both built in output, I can't here anything in my mac, unless i press the PFL button. When I plug in my DJIO with my headphones plugged into it and set my audio to Two Souncards, Channel 1&2: Master, Built-in output, Channel 3&4: headphones, DJIO, I can not hear anything in my headphones, even if push the PFL, but the music is coming out of my computer. This Problem has been going on for 2 days now
geposted Fri 09 Dec 16 @ 2:42 pm
If you are using the DJIO then you are using one soundcard, not two? thats why it is coming out of the computer. The two soundcard option is for when you have a soundcard/interface with only one output so you have to monitor through the computer headphone jack
If you don't have your IO connected just select Single Output with Master set to 1&2.
No headphones.
If the IO is connected, select 2 Soundcards, set Master to built-in soundcard 1&2 and Headphones to IO soundcard also 1&2.
If you do not get sound from the specific headphones out at the IO, maybe you need to connect your Headphones with something like this to the IO's master out.
http://www.conrad.com/ce/en/product/325108/RCA-Jack-Audiophono-Extension-cable-2x-RCA-plug-phono-1x-Jack-socket-63-mm-020-m-Black-SpeaKa-Professional
Still does not work, even tried reinstalling
might be an idea to upload a screenshot of your sound configuration.
