Forum: VirtualDJ 8.1 Technical Support
Topic: Numark N4 Help!!!!
Been using my controller fine tonight and it's stopped doing what it normally does.
i usually have to press the "Effect" button once to turn it on but now i have to hold shift.
Same thing goes for the loop, press "loop out" once to show it on the waveform and hold shift and loop out to extend, loop out to end it, now it's the other way round.
When i do have a loop playing the jog wheel would usually move the track forward now it moves the loop, not what i need at all.
i've tried resetting the default mapping on the settings and it hasn't changed, can anyone tell me what i've done?
Thanks
geposted Sat 10 Dec 16 @ 10:48 pm
geposted Sun 11 Dec 16 @ 2:56 pm
