Rolled back to 2857 because the keyboard issues STILL aren't fixed on Mac...
When I load a song into the deck now, I get this "STREAMING DECK 1" message. All local files. Never done that before. Any idea on cause and fix?
geposted Sun 11 Dec 16 @ 11:17 am
What file size are they, how much memory do you have on your machine, how many decks do you run?
geposted Sun 11 Dec 16 @ 12:59 pm
Does it with all files. 16GBs. Does it with all decks, even if I run just one.
geposted Sun 11 Dec 16 @ 8:00 pm
If you go back from 8.2 to earlier, it's possible that the maxPreLoadLength option got reset, so you may want to set it back to default (40)
geposted Mon 12 Dec 16 @ 7:11 am
