Topic: VCI-400 Vinyl button behaviour
Hi
Mapping slip_mode to the "Vinyl" button on the VCI-400, the button seems to only allow slip mode while pressed, not toggle on/off. (slip_mode works as toggle on/off when mapped to other VCI-400 buttons)
Any insight or solutions?
Thanks!
geposted Mon 12 Dec 16 @ 1:00 am
That's because the VINYL button is a toggle one (1st press On, 2nd press off), so better choose a different button to assign slip_mode
Hmmm... yeah, it seems to, but that IS how I want to use the function...
One press for slip_mode on...
One press for slip_mode off...
That's how the equivalent works in Traktor, so I'm not sure why the hardware limits the function here.
Cheers,
How is the button mapped ?
There is also a strong possibility, the VINYL button to work in "Hardware" mode, meaning that when the button is OFF, even if you have not assigned that as vinyl_mode, the Key that offers the TOUCH_JOG may not be offered, thus no Slip mode applied when Jog is touched. If that is the case, and you have mapped the button as vinyl_mode & slip_mode or just slip_mode, the Hotcues and Loops should act temporary and the Deck Options button on the skin, should flash (indicating Slip mode engaged)
It's mapped with just: slip_mode
