Topic: unable to clear sidelist
The learning curve on 8.2 is uncomfortable. I have been having issues with sound set up. Just need simple (out of headphone jack)
I can not clear the sidelist... don't see any button to clear. Please help
After researching... I can select each song and then right click and select "remove" I also watched a youtube on this very subject.
geposted Thu 22 Dec 16 @ 1:00 am
I am sure guys are willing to help. But things like what mixer/controller/amp/speakers you're using will help if someone is to help you. Or what did you tried?
In case you want to clear the whole sidelist...
1) Select all tracks with CTRL+A (CMD+A) and either right-click and remove or just press "Del"
2) Create a custom button with the action: sidelist_clear
3) Map a keyboard key with the action: sidelist_clear
