What have happened to the function of download text to audiofiles in Tag Editor ?
geposted Sat 24 Dec 16 @ 4:20 pm
It has been moved to the video editor
geposted Sat 24 Dec 16 @ 5:16 pm
Ahh, thank you !
geposted Sun 25 Dec 16 @ 7:21 am
Thanks again, found it now..
geposted Sun 25 Dec 16 @ 11:07 am
I just had a look into this. If you press the 'overlay lyrics' button, two large white blank boxes appear. The left hand box has 'netsearch' written above it.
However, that's as far as I could get.
There doesn't seem to be a way of enabling text download. There's no button next to the 'netsearch' text. Mouse clicking (both left and right) doesn't bring up any menus.
??? Not exactly obvious how it's supposed to work...
[later] OK I read the info here. It seems you have to either write it in manually or copy and paste it in from an external source. Apparently the white box on the left (under 'netsearch') is supposed to auto populate - but I got nothing when I tried.
geposted Sun 25 Dec 16 @ 11:17 am
I don think this works as good as it did before, now I have problem to play the files after I have saved them ?
geposted Wed 28 Dec 16 @ 8:47 am
Bumping this, as I would like this feature to work properly !?
geposted Sun 26 Mar 17 @ 9:36 am
