Forum: Old versions
Topic: Vdj 7 home it says i only have 10mins
Hi, when i open Vdj 7 home it says i only have 10mins to use the controller denon mc 6000, is there another version i should have other than the home vdj 7 , vdj 8 works but i thought the infinity 8 included the vdj 7 pro ..
thanks Mark..
geposted Wed 28 Dec 16 @ 11:22 pm
geposted Thu 29 Dec 16 @ 12:02 am
Hi, i just downloaded Vdj 8 on the 12/22/16, i have the VirtualDJ 8 PRO Infinity license but not the VirtualDJ 7 pro ..
geposted Thu 29 Dec 16 @ 1:18 am
There's something strange going on because you only have a single star under your forum name. With a Pro license you should have three.
I think you should contact support....
geposted Thu 29 Dec 16 @ 9:39 am
I just got the pro 8 never had vdj before , all it shows under my license's is the vdj8 and no where to download the vdj7 pro.
geposted Thu 29 Dec 16 @ 5:12 pm
As above, there is something wrong with your account. Contact support as no-one on the forum can help you.
geposted Thu 29 Dec 16 @ 5:23 pm
They said it was reset thanks for your help..
geposted Thu 29 Dec 16 @ 8:50 pm
