How do I get to add this to a button???
similar to this: search '`get_browsed_artist`'
getting this:
sampler_group_volume, skin_panelgroup etc.
Theres nothing in the documentation or the wiki (http://www.virtualdj.com/wiki/VDJscript_verbs_v8..html)
Is this not possible at this time??
thnx in advance
Would also be useful for assigning tracks to a group.
getting this:
thnx in advance
geposted Thu 12 Jan 17 @ 1:59 pm
Can you please explain "group" ?
geposted Thu 12 Jan 17 @ 8:13 pm
geposted Fri 13 Jan 17 @ 10:24 am
There is no script for that, the only time saver I can offer is... mark all the files you want to tag to a specific group a specific colour [one you haven't used elsewhere] then once you've finished colouring, recurse the database, order the files by colour select all the files that are the specific colour and then tag them all in one go.
geposted Fri 13 Jan 17 @ 11:10 am
If you are trying to search based on the "grouping" field, in theory, you could use..
search '`get_browsed_song "grouping"`'
but since there is no option for Search to search within the Grouping field, you will not get the expected results.
As for VDJ script actions for any database field, you can use ..
get_browsed_song "fieldname"
or
get_loaded_song "fieldname"
or
geposted Fri 13 Jan 17 @ 11:16 am
Thnx for the response guys
and Thnx to you Sir LocoDog
geposted Fri 13 Jan 17 @ 12:32 pm
there's always my library/extras/grouping
geposted Fri 13 Jan 17 @ 1:01 pm
