Recently I have only been logged in to two machines per the EULA, but I'm finding I keep having to log in randomly for no reason. I never manually log out or log in with a third machine.
Can someone please check the server settings as I can't figure out why it's doing this and it's only been happening for a week or so.
Thanks.
Thanks.
geposted Fri 13 Jan 17 @ 3:30 pm
Heard of it too. But never experienced it myself.
I believe you are a Windows user? Because I only heard it happening from MAC users.
geposted Fri 13 Jan 17 @ 3:33 pm
Yes, Windows 7 on one machine and Windows 8. on the other.
I tried the licence.dat trick and it definitely does not work for me.
geposted Fri 13 Jan 17 @ 3:56 pm
if they find nothing wrong with the Server, try changing your pword and see if it still happens.
geposted Fri 13 Jan 17 @ 4:11 pm
i have noticed if i login to the forum from work or places other then home that can log me out from vdj sometimes .. could be this?
geposted Fri 13 Jan 17 @ 8:16 pm
The forum only allows you to be logged in on one device or web interface, however my issue is with the software itself which should allow two concurrent logins and they should stay live unless you either log out or use a third machine.
This is worrying me a bit now.
geposted Fri 13 Jan 17 @ 8:19 pm
yes i was talking about the software logging me out when i login the forum in different places.
not while i am using it but between uses
geposted Fri 13 Jan 17 @ 10:30 pm
