Topic: Remove previously stored points
Barrow1Home userMember since 2017
When I load a song to a deck that I have used before, it automatically loads any cue points etc that were used last time. How do I delete all previous settings and start afresh.
Tried deleting History in left panel and deleting Database.xml from Virtualdj folder but makes no difference. Using on Windows 10 by the way.
geposted Mon 16 Jan 17 @ 7:30 pm
You want the hot cues to be deleted just once in order to start fresh, or EVERY time you load a track on a deck ?
If you want to delete everything to start fresh then all you have to do is to delete "database.xml" file from VirtualDj folder AND any other drive that has media files you use with VirtualDj
geposted Mon 16 Jan 17 @ 7:34 pm
Thanks for quick response. Worked just fine. I was deleting database.xml from C drive but not D drive. Now all clean to start again. Thanks again!
geposted Mon 16 Jan 17 @ 8:31 pm
