Why did support close for helping registering virtuel dj 8 ?????
I DID install the driver for my controller FIRST, and then the software
HOW do i register virtuel DJ 8.2 ???????
geposted Fri 20 Jan 17 @ 9:37 pm
When you run VDJ, a box appears asking you to log in with your forum user name and password. That's how VDJ recognises your license.
geposted Fri 20 Jan 17 @ 10:09 pm
When you go to my account/licenses, what does it say?
geposted Fri 20 Jan 17 @ 10:11 pm
When i run VDJ, no box appears.
When i go to licenses in VDJ, there is nothing in the "Current Licenses"
When i "Log in" in VDJ, a welcome to VDJ 8 appears and a "Welcome" says reserve your unique DJ name"
Which i did everytime a couple of times it appeard, i got tired of it, so i uncheked the "Dont ask again" which didnt helpd...
But i did now again make a unique dj name, and it ask for a email, and password, then i used my email, and password i got from you
then it AGAIN...says "the email is already registred bla bla bla...
And then i get a new password from you again...
then i use the new password, and under "current Licenses" my controller shows
shall i enter a keycode??
then i disconect internet, and use VDJ, and after a while a popup says its not free and disables the controller.......
geposted Sat 21 Jan 17 @ 8:05 am
first of all the login you need is the one for this forum the user name -> user15016742 and what ever password u chose for it.
if that still doesn't work run the addon below and try again.
http://www.virtualdj.com/plugins/index.html?addonid=80191
geposted Sat 21 Jan 17 @ 11:36 am
Aaah...from.....the Forum??????
"well why dont we make it more complicated for the user to use a completely other login from....a forum"...well well well...
"we couldnt dream of register the software with his email and the password...ooooh noo thats to easy for them"
From the socalled online chat support "you have to use MASTER+internal sound card
I then had to tell him that no such thing as "MASTER" is mentioned in my VDJ
about then he closed the chat........
I did that as you can see in my name, and when trying to log in:
"Unfortunately This name has already been reserved bla bla bla...
i will try the plugin
geposted Sat 21 Jan 17 @ 11:59 am
My antivirus tells me that the plugin is a virus ???
geposted Sat 21 Jan 17 @ 12:01 pm
No, the utility/tool is not a virus. It's only being flagged as one because it checks and modifies your computer's 'hosts' file (and some viruses or cracks do that too).
Of course VDJ requires your forum information - because this is where you bought the license and VDJ needs to verify your identity. Therefore any email address that you want to use for logging into VDJ has to also be registered to your account here - otherwise how do Atomix link your details to your license?
Also, there is a master output on all copies of VDJ. That's how you hear the music.
geposted Sat 21 Jan 17 @ 12:17 pm
I have Avid Protools 12, and Uvi falcon, and Reaktor 6, and none of them do registering like that, but okay.... ;-)
Yes now i see the MASTER, its under the OUTPUT, CARD, INPUT
Outputs
master
the plugin wrote "Host file not changed!"
is that ok or ?
i tried again to log in with my kschumacher = "Unfortunately This name has already been reserved bla bla bla..."
geposted Sat 21 Jan 17 @ 12:40 pm
fyi don't create a new user just login :-)
it has already been created here
geposted Sat 21 Jan 17 @ 12:45 pm
....will someone help me registering the ....program FROM START
or shall i contact my bank and get my money back......
geposted Sat 21 Jan 17 @ 12:48 pm
It is already registered!
You are showing as a Controllerist with two stars. If it was not registered, you would be shown as a Home user.
geposted Sat 21 Jan 17 @ 12:55 pm
Ok? i try to use it for a while again and hoping that the popup ,free thing, wont show again
i will change the usb cable just to be sure
geposted Sat 21 Jan 17 @ 1:31 pm
Your VDJ is registered here, so now you should be able to log in to your VDJ software (with your forum name and password) and see your controller license showing in the config area for licenses.
geposted Sat 21 Jan 17 @ 1:48 pm
I have that showing when im logged in, (controller) but that registration dispears when im offline
so that is normal?
geposted Sat 21 Jan 17 @ 4:18 pm
You don't need to log out of VDJ once you have logged in.
Your license information is stored in a file which is created once VDJ confirms that you have a license. If you log out, then that file is deleted.
You can be away from an internet connection and VDJ will still work with your controller because it will check for the file when it starts up.
So....log in, then (when you have finished DJing) close VDJ without logging out. When you start VDJ again, you will still be "logged in" because the license file is still there.
geposted Sat 21 Jan 17 @ 4:36 pm
hmmm...
i dont want to be online so i disable internet for a long time (other computer)
is the licens deleted on every restart/shutdown of windows then?
geposted Sat 21 Jan 17 @ 4:43 pm
No - as I said, the license gets removed if/when you log out of VDJ. You can close VDJ without logging out first.
Logging out removes the license from that computer (it's in case you need to use VDJ on a computer which is not yours). You can log in and use your license, then log out and your license on that computer will be gone.
So just do not log out. You can close VDJ. You can shut down your computer.
Log in = "create license on this computer"
Log out = "delete license from this computer"
Read here http://www.virtualdj.com/wiki/Use%20VirtualDJ%208%20Offline.html
geposted Sat 21 Jan 17 @ 4:49 pm
it didnt work....until i noticed a thing in VDJ nobody has told me.....can the so called support guess what it is...?
Dont worry i wont buy a product from you again, worse support i have experinced yet !!:
i used allmost 3 days to get it to work!!! and being kickd via support-chat!!
geposted Sat 21 Jan 17 @ 5:18 pm
Well to be honest, people shouldn't have to tell you. You have the program right there in front of you. You have the instruction manual.
We can't read your mind. We don't know what you have and haven't noticed in VDJ.
Anyway, problem solved I hope :-)
geposted Sat 21 Jan 17 @ 6:55 pm
