Topic: mcx8000 screens come on randomly
hh73PRO InfinityMember since 2006
installed the latest build on 8.2, i also re installed windows 8.1 because the latest builds are really bad. problem is the screens now are not displaying at all today. last night was ok. yes i have latest firmware.
geposted Sat 21 Jan 17 @ 6:00 am
Probably something went wrong with the drivers with the new installation of the OS.
Uninstall MCX8000 drivers.
Reboot computer.
Install MCX8000 drives
Reboot computer
Plug MCX8000
See if that helps.
geposted Mon 23 Jan 17 @ 10:13 am
i did a 3 hour set, and it seemed ok. but the left screen seem to lag 5-10 seconds in time compared to whats displayed on my monitor still. no biggie. but the right screen is perfect.
geposted Mon 23 Jan 17 @ 7:55 pm
If you are getting a 5-10 second lag in one screen, then I would think it was important for the devs to know.
geposted Mon 23 Jan 17 @ 8:13 pm
yeap
geposted Tue 24 Jan 17 @ 4:28 am
read on the serato forums the lag on the screens is happening with some users too. some say lower the latency. i installed serato (what a pita)......it will take all night to analyze my files. but it automatically set my latency at 5ms. where vdj uses 11. otherwise its a denon thing. and i asssume a firmware upware will fix it.
geposted Tue 24 Jan 17 @ 6:22 pm
