Forum: VirtualDJ Skins
Use this forum if you have questions about skin development, or if you want to communicate with skin developers.
Topic: Skin For Numark NVii
Is there a skin designed for the Numark NVii controller?
geposted Sun 22 Jan 17 @ 10:13 am
If you mean "Is there a skin that duplicates the NV controls on screen?" then the answer is no.
Any VDJ skin will work with any controller.
It is not necessary for the skin to look like the controller in order for it to work.
When using real hardware to control VDJ, the only elements required on screen are those not provided on the hardware itself. E.G. if the hardware has jog wheels, then jog wheels are not required on screen. You have real ones.
I would suggest using a skin which displays a large browser, visual feedback of pad status and visual feedback of effects selection. Anything else is eye candy.
geposted Sun 22 Jan 17 @ 10:39 am
SliverSleek is what I recommend you use, it's about the best skin there is in my opinion .
geposted Mon 23 Jan 17 @ 12:22 am
i need skin for numark nvii plz
geposted Sat 17 Jun 17 @ 10:19 pm
yes there are skins for the numark nv but unfortunately they are not available on virtualdj.com so you have to download them from a third party which not every one likes to do
geposted Tue 27 Jun 17 @ 3:40 pm
where did u acquire skin above in pic?> looks fantastic.
geposted Mon 27 Nov 17 @ 11:30 pm
Personally I find it awful. Lots of wasted space there, just to "duplicate" on screen what you have in front of you already.
If I can count correctly the browser is limited on 8 tracks? Why?
Each one with his own, but I don't find this skin any practical at all. Especially for a controller like NV that can show some useful information on it's own screens and therefore you don't necessary need to see that info on your computer screen twice
geposted Tue 28 Nov 17 @ 10:35 am
was messin round w the slick2 for 4 decks (not numarknv2 yet, im waiting on delivery, so im using a basic numark pro3,) and i like that slick one, and my go to has been for past year plus the old school (2 turntable) skin. i figure w the nv2 screens the laptop use will be even more minimal, as its been with even the npro3 and only really referenced for beat/wave and length of song, etc. looking forward to the nv2 and i got that skin pictured above and its beyond redundant and seemingly makes it more complicated than needed, tbh.
geposted Tue 28 Nov 17 @ 6:56 pm
Im am JavierDanceBeats. Creator this Skin.
geposted Sat 09 Dec 17 @ 11:26 pm
Why is the right player mirrored?
And not like the original NV
Greatings
geposted Mon 11 Dec 17 @ 2:42 pm
No, it's the left one that's been swapped. Both pitch faders should be on the outside.
I agree with Phantom anyway. It's a complete waste of space to duplicate on screen what you already have right in front of you as hardware.
geposted Mon 11 Dec 17 @ 5:45 pm
[quote=groovindj]No, it's the left one that's been swapped. Both pitch faders should be on the outside.
Yes , mean the Right Deck..
geposted Tue 12 Dec 17 @ 4:40 pm
This is the NV ;-)
geposted Tue 12 Dec 17 @ 4:42 pm
