I have 155 tracks with ratings in my iTunes Library. When I import the ratings from iTunes it says it's imported 496 ratings. I have spot checked several of the songs that now have ratings showing in VirtualDJ and confirmed that they do not have ratings in iTunes or associated with the file themselves.
geposted Mon 23 Jan 17 @ 9:04 am
Bueller....Bueller?
geposted Tue 24 Jan 17 @ 11:05 pm
I heared that this problem has been fixed. However, I'm not able to see my iTunes ratings when browsing the playlists in VDJ 8.
The iTunes playlists are imported properly, though without the ratings.
How can I import all of my iTunes ratings into VDJ 8?
geposted Sat 04 Mar 17 @ 12:57 pm
I think you have to do a Batch -> Reload Tags on the iTunes files.
geposted Mon 06 Mar 17 @ 9:47 am
Before doing a Batch reload of Tags, you also need to make sure the setting getRatingfromTags is set to Yes (its set to No by default)
geposted Mon 06 Mar 17 @ 12:02 pm
