About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: VIRTUALDJ 8 PRO "INFINITY" - Page: 1
Will the VIRTUALDJ 8 PRO "INFINITY" work with my Behringer DDM-4000?
geposted Mon 23 Jan 17 @ 4:05 pm
Yes there are other people using it, after a quick search.
geposted Mon 23 Jan 17 @ 4:12 pm
OK, so does Infinity mean that we will automatically get upgraded to any and every update for VDJ? Like for example, will we automatically get upgraded to VDJ 9, 10, 11 so on...?
geposted Mon 23 Jan 17 @ 7:41 pm
That's the way it has worked until now. There's no absolute guarantee in life however it's been like that since 2003.
geposted Mon 23 Jan 17 @ 7:46 pm
You do not automatically get updated. It's up to you to decide to install the updates. You are eligible for all updates and upgrades, at no extra charge. As stated, this is the way it has been, but anything could happen.
geposted Mon 23 Jan 17 @ 7:51 pm
Just a heads up...
Behringer DDM-4000 is not officially supported, so wont play right out of the box.
You will be able to use it as an "analog dj mixer" with External mixer Audio setup. For this , a Analog Mixer Plus, Pro Infinity or Pro subscription License will be required.
In order to use this unit as a MIDI controller as well, and get 100% of the unit's functionality, you will need Pro Infinity license and also create a custom definition
There is also user's ver7 Addon (available for Pro Infinity users) for the unit http://www.virtualdj.com/addons/8198/Behringer_DDM4000_Def___Mapper.html , which may require some changes and/or additions in order to work with version 8
geposted Tue 24 Jan 17 @ 2:30 pm
is anyone else having an issue with internet connectivity
geposted Mon 24 Apr 17 @ 9:08 pm
No, but your question has nothing to do with this topic. Please do not hijack another persons thread, thank you.
geposted Mon 24 Apr 17 @ 11:25 pm
i cant download v8 pro just paid 33.00 nzd
geposted Fri 06 Apr 18 @ 6:50 am
geposted Fri 06 Apr 18 @ 6:51 am
To be clear, there is only one version of the VDJ software to dowload. If you have no license, then it works as the free home version.
Once you do have a license, you need to log in to VDJ, which will then work as whatever version you purchased.
geposted Fri 06 Apr 18 @ 5:27 pm
I have a Rane SL1 with 2 Audio Technica LP120 and the Numark M6 mixer and running windows 7 pro. Will I be able to hook everything up with Virtual DJ?
geposted Sat 04 Aug 18 @ 8:20 pm
yes
geposted Sat 04 Aug 18 @ 9:41 pm
Greetings VDJ team, Can someone help me out?
When recording with VDJ 8, 2018 The samplers keep appearing on my video output, and loop effect, it does appear on my video mix. What can I do please,
Thanks.
geposted Tue 14 Aug 18 @ 7:06 pm
I WANT TO USE VIRTUAL DJ 8 PRO ON MY NUMARK NS6 AT HOME
geposted Wed 12 Sep 18 @ 11:13 am
Sure, just buy a license.
By the way, please stop SHOUTING.
geposted Wed 12 Sep 18 @ 11:39 am
Pls I need d download link for vdj8 pro full version
geposted Sat 15 Sep 18 @ 10:01 pm
geposted Sun 16 Sep 18 @ 1:36 am
vIRTUAL DJ FUUL BUENO
geposted Sun 16 Sep 18 @ 2:56 pm
JOSRRRHome userMember since 2018
how can i get free music and also my using virtual dj 7 dosenot browser on internet
geposted Sun 16 Sep 18 @ 3:25 pm
Seite : [>] [>>]
87%
