Hello!
How to get and edit, default skin browser side script???
J
J
geposted Tue 31 Jan 17 @ 12:02 pm
Could you please explain better what you want to do ?
What do you want to add/remove/modify ?
geposted Tue 31 Jan 17 @ 12:19 pm
Hi!
I wish modify browser windows:
add extra panel to file browse button and in those panel add prelisten panel with song info fields
J
J
geposted Tue 31 Jan 17 @ 3:03 pm
geposted Tue 31 Jan 17 @ 3:14 pm
thank You!
yes I read before those links :).
hmmm, but I don't want build browser side from begining, just make small modificatons in exiting skin, but i can't find in skin xml files, bowser script :(
J
J
geposted Tue 31 Jan 17 @ 3:27 pm
The default (standard) browser is a fixed thing. Its design is set.
If you want to add things that don't exist in the default browser, you have to write a custom one from scratch.
Unfortunately custom browsers still have bugs and also some things are not documented.
geposted Tue 31 Jan 17 @ 6:01 pm
Thank You Groovindj!
maybe is possible get base script for browser???
J
P.S. probably I wish only small thing, add extra panel, for example top of root folder browser and add simple prelisten player (like in Trakotr)
now prelisten player can open in side panel, but now it takes so much place, for a prelisten don't need see song information,
is enough if see only play button and play bar
J
geposted Tue 31 Jan 17 @ 8:43 pm
