Forum: Old versions
Topic: Question - 7.4 & MacOS Sierra
HI
I may have to upgrade my MacBook Pro and as such would be getting a MacBook Pro 2016 version. This of course would have MacOS Sierra on it. Will Virtual DJ 7.4 work with Sierra and a Hercules RMX 2 controller?
I know version 7.4 isn't maintained anymore, however I prefer 7.4. If I can't use 7.4 is VDJ 8.2 stable with Sierra and Hercules RMX 2?
Please advise
Thanks
geposted Sun 05 Feb 17 @ 3:49 pm
geposted Sat 11 Feb 17 @ 8:05 pm
I don't think many people have new Macs as they are so frickin expensive. Not heard of 7 not being supported on Sierra.
geposted Sun 12 Feb 17 @ 1:47 am
dcomoPRO InfinityMember since 2012
I have a few of the new Mac's now and VDJ 7 works fine on them under Sierra. I also know that Hercules also supplies a compatible Sierra driver for the RMX2.
(https://support.hercules.com/en/product/djconsolermx2-en/)
In theory, you shouldn't have any issues at all, however I would STRONGLY suggest that you move to VDJ 8.2 for a massive number of reasons. (There is no reason to user VDJ 7 any longer.)
geposted Fri 17 Feb 17 @ 3:40 am
