Forum: Music discussion
Topic: Remix showing after song title.
Hey all, I've read just about all the forums and cannot find the answer, so here I am. I have been using VDJ 8 Pro and broadcasting to shoutcast servers successfully for 3 months now. Previously using VDJ 7 Pro. Usually never have a problem connecting or using the software with my Pioneer XDJ-R1. The real issue is:
When I am broadcasting, VDJ is sending the track artist and title to the server, which is completely fine with me, I want it to do that, However, when it displays on either the web stream or iTunes or the allradio app or anywhere for that matter it displays "remix" after the title. no space, no special marks or anything just "remix"
EXAMPLE: Current Song: Blake Shelton - Neon Lightremix
It doesn't matter what song or how many options I try, IT WON'T GO AWAY. What gives? Anyone.
geposted Fri 10 Feb 17 @ 3:22 am
I have the same problem. A solution would be nice.
geposted Mon 03 Jul 17 @ 7:28 am
Make sure you are using the latest version of vdj, and try to reset the broadcastSongInfoFormat option.
geposted Mon 03 Jul 17 @ 9:19 am
Well go to your Settings --> Options-->Broadcast-->BroadcastSongInfoFormat
and change it from %artist - %titleremix into %artist - Remix
should work on this way but I didn't try :)
geposted Sun 13 Aug 17 @ 3:00 am
