Hi, I have noticed a glitch when creating a video overlay for an audio only file (dragging a video onto an audio clip)
This is my procedure (and you can clearly see the annoying issue I encounter)
1) AUDIO ONLY FILE PLAYING IN VIRTUAL DJ
![](/img/222543/27073/virtualdj video edit 01 audio only track.png)
2) DRAG A VIDEO FILE ONTO THE AUDIO
![](/img/222544/22482/virtualdj video edit 02 drag video to create video edit.png)
3) THE RESULTANT EDIT (FROM THE DRAG) CREATES 50 UNWANTED REPEAT CLIPS
![](/img/222546/5769/virtualdj video edit 03 unwanted repeat clips.png)
4) THIS IS WHAT IT SHOULD LOOK LIKE FOR A SHORT VIDEO CLIP THAT IS REPEATED ACROSS THE WHOLE AUDIO FILE....
![](/img/222547/16142/virtualdj video edit 04 this is what it should look like.png)
geposted Sat 18 Feb 17 @ 11:22 am
Does this zzzz file you drop to the Video Preview have sound or is it just a silent video ? Probably tries to match some audio automatically. I suppose this doesnt happen when you are manually overlay the video using the Video Editor , right ?
geposted Sat 18 Feb 17 @ 11:44 am
if I use the video editor to introduce the same clip it behaves OK. The video clip has no audio. It's a shame the drag and drop feature is flawed.
geposted Sat 18 Feb 17 @ 5:12 pm
diamond video disco wrote :
..The video clip has no audio.
Ok, a fix for such cases will be provided in next update.
geposted Mon 20 Feb 17 @ 1:01 pm
i'm having problem with my music videos when play the video it will play the music but freezes the video
geposted Sat 09 Dec 17 @ 11:53 pm
