HI i seem to be not getting any help with this
since i updated the asio drivers will not work. i cant get the controller to work and i have no idea what to do. i keep getting asio error
geposted Sat 18 Feb 17 @ 8:28 pm
might need to do the firmware as well -> https://www.pioneerdj.com/en/product/controller/ddj-sz/black/support/#info
i would reinstall the asio driver
geposted Sat 18 Feb 17 @ 9:23 pm
can you tell me how to re-install the viso driver
geposted Sun 19 Feb 17 @ 1:20 pm
download the file and install in again?
geposted Sun 19 Feb 17 @ 1:44 pm
I downloaded the updated and reinstalled firmwar and still the same problems. is there anyone who can get on line and take a look. i have a gig in two hours
geposted Sun 19 Feb 17 @ 2:57 pm
HI ok this is strange, i always plug in my usb on my left side i have 2 usbs on the left and right. bolth the usbs on the left are not connecting with the ddj sz but the second i plugged the controller/ usb into either of the usb ports on the right side it started to work fine so any idea why the ports on the left side stopped working for the controller? my mouse and external hard drive work fine on the left side just not the controller? any thoghts or ideas, because i have to tell amienware and have there teck fix it.thanks for the help. i can relax now.
geposted Sun 19 Feb 17 @ 3:35 pm
When you plug your DDJ-SZ on the left side it's quite possible that Windows are using it's soundcard as their default playback device.
ASIO drivers don't like that and fail to initialize.
Solution:
1. Plug your DDJ-SZ on your "left" side USB port
2. Go on Control Panel -> Sound applet
3. Make sure that DDJ-SZ soundcard is not used as Windows default playback and/or communications device (does NOT have a green icon on it)
4. Try again
If you have more USB ports repeat the above procedure for the rest USB ports as Windows remember your settings not globally but for each different USB port.
Solution:
4. Try again
geposted Sun 19 Feb 17 @ 4:03 pm
