I'm using the Virtual DJ 8.0 version on Windows 10 with a Behringer BCD3000. When clicking the + and - pitch buttons, nothing happens on screen. They only light up, but the pitch doesn't change. I really need these buttons to work because the pitch slider of my Behringer is broken and these buttons need to replace the slider. Help!
geposted Sun 19 Feb 17 @ 3:30 pm
One thread on a topic is enough, please don't make duplicate posts, it's known as crossposting and it annoys the people who may help you,
It's generally frowned upon on any forum
the buttons on their own activate pitch bend which momentarily changes the pitch but pitch reverts to what it was on button release, you want to use shift+button to change the pitch
geposted Sun 19 Feb 17 @ 3:39 pm
Yes I know and I'm sorry for that, but there wasn't a forum for my version (8.0). So just to be sure, I posted it on the forum of the 8.1 and 8.2 version. That's why :)
geposted Mon 20 Feb 17 @ 7:46 am
I tried to use the shift combination, but still nothing happens... And as you said: that without shift the pitch should change temporarily, that's also not the case at all..
geposted Mon 20 Feb 17 @ 7:55 am
Show your mapping for said buttons
geposted Mon 20 Feb 17 @ 10:25 am
By "shift" , we mean the button on the controller mapped to toggle the shift action or a shift variable, and not the SHIFT on your keyboard.
On the BCD3000, the key named as EXT IN B is mapped as "shift", so to get the pitch fader up/down, you need to use the PITCH BEND buttons while the EXT IN B key is pressed.
If you want to control the pitch with those buttons, without having to hold the Shift button, you need to change the actions of the PITCH BEND buttons from ..
to..
You can also choose a different step for pitch, or you can use pitch +/-X 'absolute' or pitch +/-X bpm
var $shift ? pitch -0.001 : pitch_bend -1% 500ms
var $shift ? pitch +0.001 : pitch_bend +1% 500ms
to..
pitch -0.001
pitch +0.001
geposted Mon 20 Feb 17 @ 12:24 pm
