FYI, I have created a new version of my mapping and definition file of MixVibes VFX Control to work with Virtual DJ.
* VU Meter added on leds above the jogwheels
* Smarloop length leds are working now when a loop is active (I'm still looking to add view on loop length parameter when loop is not active).
I don't know where I have to send it to make it available for the cummunity ?
But for the moment, if interested, send me a private message with your email and I will send it to you.
Have a nice day,
Sterput
Have a nice day,
Sterput
geposted Tue 28 Feb 17 @ 8:09 am
Curious on how you managed this without any Pro License, but in any case, if you want to share it with all the members of this community, you can upload your files here http://www.virtualdj.com/plugins/upload.html
Your files will be available as soon as those are tested and approved from our Staff.
geposted Wed 01 Mar 17 @ 1:31 am
Thx djdad, I uploaded it today and hope that it will be useful fore some users.
I'm not a professional and used only VDJ for my personal fun.
I hope that I will get some help to improve this mapping.
geposted Thu 02 Mar 17 @ 3:44 pm
Reviewing your files.
Only 1 thing to change/edit please..
Instead of ..
<button note="0x1A" name="1-PLAY_PAUSE" deck="1" channel="0" />
<button note="0x1A" name="2-PLAY_PAUSE" deck="2" channel="1" />
have..
<button note="0x1A" name="PLAY_PAUSE" deck="1" channel="0" />
<button note="0x1A" name="PLAY_PAUSE" deck="2" channel="1" />
and then in mapping simply have..
<map value="PLAY_PAUSE" action="play_pause" />
Please make this change for all keys available on both sides (provide the same name with only the deck="x" to differ
This will offer the ability to the users to map the PLAY_PAUSE button once in the Mapping instead of twice
Thanks
Instead of ..
have..
Thanks
geposted Thu 02 Mar 17 @ 8:03 pm
Thx djdad, I uploaded the new version with the optimization and added some new buttons
geposted Mon 06 Mar 17 @ 8:42 am
Addon is available http://www.virtualdj.com/plugins/index.html?addonid=80574
geposted Tue 07 Mar 17 @ 3:24 pm
djdad,
Can you say me why some leds are "off" at start when they are mapped with action="on" ?
To get these led "on", I need to change the mapping to "off" for example and put it back to "on".
Thanks and kind regards
geposted Fri 10 Mar 17 @ 8:59 am
Provide an example of a LED that behaves like this
geposted Fri 10 Mar 17 @ 9:02 am
<map value="LED_FX_ON_OFF" action="on" />
<map value="LED_LOAD_A" action="on" />
<map value="LED_LOAD_B" action="on" />
<map value="LED_BEND+" action="on" />
<map value="LED_BEND-" action="on" />
<map value="LED_RANGE" action="on" />
<map value="LED_MATCH_SYNC" action="on" />
<map value="LED_MT" action="on" />
<map value="LED_LOCATOR_1" action="on" />
<map value="LED_LOCATOR_2" action="on" />
<map value="LED_LOCATOR_3" action="on" />
<map value="LED_LOCATOR_4" action="on" />
Some are lighting and some not, it's not always the sames
geposted Fri 10 Mar 17 @ 12:19 pm
Appears the unit cant handle fast LEDs refresh.
OK, here are 2 things you can try...
1. Set the ControllerRefreshRate setting to 50. If you see any improvement, try to find the best value , like 30, 40, 70 etc
2. Try to add a delay for the LEDs in the definition...
<device name=".."" .... senddelay="2" ... >
If you see any improvement, try a higher value , like 5 and see if it helps.
geposted Fri 10 Mar 17 @ 2:10 pm
Thx, I will try and keep you informed
geposted Tue 14 Mar 17 @ 8:33 am
Thanks djdad, I added delay in the device definition and problem is solved.
I add this new version.
geposted Thu 16 Mar 17 @ 8:38 am
Update is now available.
Please next time you need to update any Addon, do not re-submit with a new name. Update the existing and change the version number instead of the name of the Addon (use the green button you see here http://www.virtualdj.com/plugins/upload.html )
Unfortunately, your new Addon now has a new link http://www.virtualdj.com/plugins/index.html?addonid=80574
I edited the link posted above, but not sure if you have used that in other topics.
geposted Fri 17 Mar 17 @ 12:04 am
