Topic: 8.2 build 3621 - Page: 1
Asked it several times, got a lot of negative reactions...
Great minds think ahead...
Thank you very very very much, Atomix.
geposted Wed 01 Mar 17 @ 8:39 am
Everyone asked for it. Now it is there and a day into the new version, not a single comment...
geposted Wed 01 Mar 17 @ 9:08 am
Holy crap .... a Spotify plugin .... and it works.
Thanks guys!
geposted Wed 01 Mar 17 @ 9:25 am
freppaPRO InfinityMember since 2002
BUILD 3619 (2017-02-25)
-Support for AKAI APC40 MKII and AKAI MPD218 added
-Fix time display for karaoke history folder not showing date
-Fix timecode bug that could make vinyl side swapping too sensitive
-Fix video edit not playing on mac with useDXVA enabled
-Fix auto-generating track edit with video with no sound
-New filter word: duplicates
-Fix Discogs cover art
-Improve group by year range 10 filter folder
-Lookup empty year and genre from discogs in tag editor using option button - - thank you for this, it works pretty good !
-Improve wave detail in bpm editor
-Show waveform overview in editors
-Fix deinterlace not working after loading a non-interlaced video
-sideview 'automix' 'blink' and sideview 'karaoke' 'blink' added
-browser_move "top" and "bottom" added
-playlist_load "append" added
-Folder Tree organization change
-Make filter folder genre split by slash optional
-color for skin text object can be action when enclosed with backtics
-browser_move, sidelist_load and karaoke_load actions added
-scratch wave respects vinyl mode setting
-Performance improvement loading big skins
-experimentalBeatAnalyzer option added
-prelisten gain also repects autogain in editors
-Deezer/Spotify plugins for pro users added
geposted Wed 01 Mar 17 @ 9:39 am
Expand "online music" in browser tree
Right click Spotify
Install plugin
Login to Spotify
Search
Easy as that.
geposted Wed 01 Mar 17 @ 9:46 am
I have never used spotify myself. Does this allow you to stream in VDJ from spotify then?
geposted Wed 01 Mar 17 @ 9:52 am
Yes. You can't cache the tracks for obvious reasons but they will load in the decks and play like any other song. It also recognizes any Spotify playlists you already have set up.
Again, not sure of the legalities surrounding this as Spotify T&C state it's for non-commercial use but I guess it's up to the individual to decide what they use it for.
It's a good move by Atomix as the current content unlimited audio package isn't very comprehensive at all.
geposted Wed 01 Mar 17 @ 9:56 am
Yeah I have mixed feelings about this. I have no doubt thousands of people will be delighted at this news, and sure i will probably give it a go. But surely it cannot be legal to use at a gig?
EDIT - Ah, read your post wrong initially, thought you said you could cache them, Guess it is good that you cant. Kind of makes it difficult to use at a gig.
geposted Wed 01 Mar 17 @ 10:06 am
so this only works if u have a paid spotify account?
geposted Wed 01 Mar 17 @ 10:13 am
Yes, I wouldn't fancy using it for all my music but the facility is there for that "one off" track you don't have .... similar to the previous Netsearch.
Not sure. I do and it works fine but not sure if it will work with free.
geposted Wed 01 Mar 17 @ 10:14 am
Well given the amount of people who seemingly tried to DJ using nothing but netsearch, i bet many people will be trying to with this.
geposted Wed 01 Mar 17 @ 10:15 am
RobRoyPRO InfinitySenior staffMember since 2012
you need to have a paid spotify account to use
geposted Wed 01 Mar 17 @ 10:25 am
Thanks for confirming Rob.
geposted Wed 01 Mar 17 @ 12:55 pm
np ;-)
geposted Wed 01 Mar 17 @ 1:09 pm
Since this is built in now, would it be a good idea to cancel Content Unlimited and do a premium account with Spotify? Or do you need to have both subscriptions? And is Deezer as good as Spotify or about the same in terms of catalog size and range of music?
geposted Wed 01 Mar 17 @ 1:27 pm
It is not possible to cache spotify songs. You're only able to stream them. Meaning, you can not play them offline.
So if you have a CU subscription I wouldn't necessarily cancel it.
geposted Wed 01 Mar 17 @ 1:41 pm
And let's not forget the fine print, Spotify is for Home use only.
geposted Wed 01 Mar 17 @ 1:46 pm
psdj03PRO InfinityMember since 2023
i cant seem t find the Spotify add on also cant seem to download the update either
geposted Wed 01 Mar 17 @ 1:47 pm
Deleted comment.
geposted Wed 01 Mar 17 @ 1:51 pm
13%
