Hi,
Would it be eas to give the option to sort by the title bar in automix. For instance if you set up a play list so track follow each follow each other smoothly if you accidentally click on the title header it re sorts them all by title thus messing up the play list.
If possible can you disable this ?
thanks
thanks
geposted Wed 01 Mar 17 @ 8:20 pm
Even if you do that, you can still get the original sort order, by right-clicking on a header and choose the option "Reset Sort order" from the top.
geposted Wed 01 Mar 17 @ 11:03 pm
