Topic: Vj loops
Any good sources for video loops anyone can reccomend? I saw an old post on a shadow dancer loop which would be cool, but the link longer works.
I purchased the VDJ toolkit from Phil Bearman which was ok, looking for more beat synced loops like that.
Thanks
geposted Thu 02 Mar 17 @ 6:58 pm
I use freeloops.tv for most of mine. You can download ten a day for free, or you can pay £50 and download everything, which is what i did, well about 800 of them anyway. all good quality, various formats and compatible with resolume. I also use VJ Hive. Very good loops, but a bit more expensive. About £5-10 per loop. I have used Fiverr as well for custom video logos which are cool.
geposted Thu 02 Mar 17 @ 9:03 pm
I'll check those out. Thanks for that!
geposted Fri 03 Mar 17 @ 12:37 am
Good suggestions, quality loops. Thanks again!
Any suggestions for visualizations that can be synced with the bpm (for mac)?
geposted Fri 03 Mar 17 @ 3:43 am
The ones on freeloops can be downloaded in DXV format for use with resolume and beat syncing video software. I am not sure its possible in VDJ to beat sync them. You can however, turn on the boom auto effect or strobe auto effect which beat syncs the effect on the videos.
geposted Fri 03 Mar 17 @ 8:27 am
LigonyHome userMember since 2016
geposted Thu 27 Jul 17 @ 7:16 am
DjButlaPRO InfinityMember since 2005
search vimeo for Beeple. His loops are hd, free and pretty sick
geposted Thu 27 Jul 17 @ 9:02 am
