Topic: 2 Decks 1 Xone
yongdadHome userMember since 2017
Am I able to control 2 decks with a single xone 1D? Tried googling but didn't get a clear answer. Thanks
geposted Fri 03 Mar 17 @ 11:13 pm
Yes. All you need to do is to map a button on the XONE1D as..
invert_controllers
and the button will cycle-assign the unit to an available deck (will toggle between Left and Right if only 2 decks are used on the skin)
geposted Sat 04 Mar 17 @ 12:08 am
