Forum: VirtualDJ Plugins
Topic: Free Virtual DJ to XML Converter (Enjoy)
** Edit: I should have made the subject Virtual DJ XML "CREATOR" since it really just creates tags for XML from objects on an image.
Working on creating a basic GUI for a plugin I'm almost done with and just wanted to share some code I modified for GUI plugin creators.
OK I don't think I'm going to work on this javascript project much more. Here is VirtualDJxml version 0.1 which is enough to get anyone quickly started with marking off buttons, text and knob areas on an image to an xml virtualdj format. After you create the code, you can copy the resulting xml into your own project and do the fine tweaking.
Photoshop has some layer tools and Gimp has an image map filter that does a little bit of work getting coordinates but this might be nicer.
http://sostrax.com/vdj/tools/VirtualDJxml/
geposted Sat 04 Mar 17 @ 2:06 am
