VDJ 8 has randomly crashed while playing normally immediately after installing the update. Also every time the song plays no matter the side, whenever I use a sample, VDJ8 crashes immediately. I noticed this problem immediately after I updated so I uninstalled and reinstalled the previous version which I still had the .exe for. This previous version still works fine, so I'm using that at the moment. FYI
I removed your first image because it had your product key on it. AMAHM
geposted Tue 07 Mar 17 @ 12:33 am
i have the same issue, probably development team work for fix this problem. Put the sample in flat mode (sample editor - drop - flat) an then try again... in flat mode work properly...
geposted Tue 07 Mar 17 @ 11:43 am
A fix will be provided in next Build
geposted Tue 07 Mar 17 @ 12:48 pm
Which build was crashing?
geposted Fri 10 Mar 17 @ 5:52 pm
The crash was in 3619/3621 now fixed in 3638
geposted Fri 10 Mar 17 @ 6:27 pm
after updating last night.my program will not respond at all
geposted Wed 18 Sep 19 @ 7:55 am
Old thread locked
@foxy2010 Please continue in your other topic and dont spread into multiple ones.
http://www.virtualdj.com/forums/230731/VirtualDJ_Technical_Support/after_update__When_i_start_my_program_it_will_not_respond.html
geposted Wed 18 Sep 19 @ 3:36 pm
