Hey all,
I have an external hard drive and have been having some problems with my database and I would like to start over and rebuild it from scratch. When I search for a song it sometimes comes up with the songs (x) out and showing them in a different location that it may have been in previous. I tried to get it to remove all missing files or folders, but it doesn't help. I would just like to start from scratch to rebuild the database correctly. Is there any way to do this?
Thanks
Thanks
geposted Thu 09 Mar 17 @ 3:48 am
in your external drive, there is a folder on the root called virtualDJ. Inside it is the database.xml - - - delete that or rename it.
(close VDJ before doing so)
geposted Thu 09 Mar 17 @ 4:36 am
