The "ON" button is stuck in the on position and I can't get it to turn off; it's highlighted in a gold color. The ON button is located on the master screen, between the REC button and the master volume. Evertime I play a song, a pop up comes up asking if I want to overwite a recorded file.
geposted Thu 09 Mar 17 @ 1:48 pm
Found solution in configuration under record section
geposted Fri 10 Mar 17 @ 12:14 am
