Topic: CUE DELAY CDJ 400 MAYA44
Hi everyone, i am experiencing seconds DELAY when I start a song. Any idea what the problem might be? Using MacPro 2012, CDJ 400 , RANE TTM 57. Many thanks! Joe
geposted Fri 10 Mar 17 @ 10:34 pm
Seconds? really seconds? Not a momentary delay (like less than a second) I suspect you have smart cue option set to on.
geposted Sat 11 Mar 17 @ 12:14 pm
Any chance Smart Play is enabled on decks (from Deck Options) ?
If not then check the latency (from Options), perhaps its set way too high.
geposted Sat 11 Mar 17 @ 2:08 pm
