Hello. I have noticed that searchLog.txt does not log the unsuccessful searches anymore. On my backup machine wich has build 3573 searchlog works ok. I'm an administrator on both machines (main: windows10, backup: windows7). I have deleted the searchlog.txt than make a search that was unsuccessful and the file (searchlog.txt) has not been created. I've reopened Virtualdj and still no searchlog.txt created. The database file and settings.xml are working as expected.Thanks.
geposted Sat 11 Mar 17 @ 8:37 am
check your settings in config/option if log unsucessfull searches is set to YES ( I think default is no)
geposted Sat 11 Mar 17 @ 12:21 pm
Hi. 'logUnsuccessfulSearches' is set to 'Yes'. Thanks.
geposted Sun 12 Mar 17 @ 8:34 pm
Works fine here (Windows 10). Verify that the /Documents/VirtualDJ folder has read/write permissions.
geposted Sun 12 Mar 17 @ 10:50 pm
Hello. Yes it has.
I have found the 'problem': searchlog.txt is updated only if 'searchInContentUnlimited' is set to yes (beside logUnsuccessfulSearches). Is this the expected behavior?
Starting this month I have canceled the Content Unlimited Audio subscription and set to 'No' searching related to CU. Why would I want to search in CU if I don't have the subscription? It has never crossed my mind that the logging of the unsuccesful searches is conditionated to CU search. Thanks.
geposted Sun 12 Mar 17 @ 11:38 pm
Ah i see.. Ok, will be corrected.
geposted Mon 13 Mar 17 @ 12:27 am
Ok, thank you.
geposted Mon 13 Mar 17 @ 8:53 am
I can confirm that the issue has been resolved in build 3663. Thanks again.
geposted Tue 21 Mar 17 @ 3:34 pm
now it works again for all unsuccessful searches!
geposted Tue 21 Mar 17 @ 6:28 pm
