Topic: Maschine V2 and Beatjump pads
I have a Maschine 2 that I want to use as a midi-controller for the different pads for the Beatjump effect. So for example, when I press key 1 on my midi-controller, I would like it to trigger one of those pads. The FX pads are 2 rows of 4x4 and my controller has 4 rows of 4x4 so I would take 2 rows from Maschine and map them. VDJ does see my controller but for the life of me, I don't see the Beatjump or anything to do with pads... Is there some way I can make this work?
thanks!
joe...
geposted Wed 15 Mar 17 @ 3:05 am
Ok.. I figured it out... I had to select the midi pad and then do a drop-and-drag to select the position on VDJ
geposted Wed 15 Mar 17 @ 3:21 am
