No, it was not played before today. I also noticed that it sometimes skips songs on the playlist.
geposted Fri 17 Mar 17 @ 1:42 pm
The file size of an error song is 0mb?
I suppose that's logical since it won't play however it was there a few minutes earlier.
Perhaps time is the critical factor, maybe the song cache is deleted after a set time, and the song is marked as used.
VDJ needs a restart to once more get these error songs.
There is an option to download these songs which I have select.
geposted Fri 17 Mar 17 @ 3:25 pm
A playlist in automix lasted around 30min this time then all the songs in the list became unavailabe until vdj was restarted.
geposted Fri 17 Mar 17 @ 5:27 pm
Yes you can use Soundcloud or Spotify or Youtube or anything you like. Its not directly from within VDJ, you just need to assign to something like Virtual Audio Cable as your default soundcard. Then on your controller, assign something like Channel 3 in Audio settings......
LINE INPUT: Line in 3 - Virtual Audio Cable
Then assign a button ACTION: linein 3
You have very little control, (You have to press play from within the web site you are playing from) but when you are desperate to play a tune from the internet, and you are confident your Bandwidth can do the job, it will do the job.
geposted Sat 18 Mar 17 @ 6:55 am
hi my spotify stop working any body knows whats going on Facebook login don't work any more
ones i get the new update from virtual dj
geposted Wed 24 May 17 @ 11:29 pm
There wasn't a Facebook login for Spotify in vdj before either.
Just login with your Spotify username and password when asked
geposted Thu 25 May 17 @ 5:32 am
So SoundCloud will not be supported in home licence?
geposted Wed 24 Apr 19 @ 2:56 pm
It is supported even with VirtualDJ Home
geposted Wed 24 Apr 19 @ 3:03 pm
