Topic: How to disable Deezer & Spotify Pop up login?
Hello,
How to disable the Deezer and Spotify Pop up login? They appear every 2 minutes and I don't have Deezer or Spotify account and I don't use them.
I don't want to see these pop up every 2 minutes when I'm working and I don't see anything in the options!
Thank you in advance for your answers.
geposted Fri 24 Mar 17 @ 12:47 pm
somewhere on the login screen there may be a small box with do'nt show again just tick that and should be ok other than that i do'nt know sorry
geposted Fri 24 Mar 17 @ 1:02 pm
Right click on them to hide in the onluine music section of the browser.
geposted Fri 24 Mar 17 @ 1:08 pm
Do you have spotify selected in the content unlimited search options perhaps?
geposted Fri 24 Mar 17 @ 1:13 pm
Yes.
So , I just have to erase spotify and Deezer and let only cuaudio?
geposted Fri 24 Mar 17 @ 1:27 pm
Yes
geposted Fri 24 Mar 17 @ 1:40 pm
Thanks!
I will try
geposted Fri 24 Mar 17 @ 1:59 pm
And thanks all for all your quick replies
geposted Fri 24 Mar 17 @ 2:01 pm
Did this fix your problem? I have the same issue and never found a proper solution.
geposted Fri 07 Jul 17 @ 4:52 pm
