Hello,
Anyone can help me?
I'm having problems with my Virtual DJ LE software in my Mac after installing an SSD disc and reinstalling all applications. It seems that I've lost pre-listening, but I'm also having difficulties with the soundcard since I can't have the sound coming from external speakers.
Thanks
Anyone can help me?
Thanks
geposted Sun 26 Mar 17 @ 11:22 am
If you by "pre listen" mean the ability to listen to one deck in the headphones while the other plays through the master, it sound like you haven't setup your soundcard yet. You do that on the first pane in the settings called "Audio"
If you tell us which controller/sound card you have someone may be able to better help you out
geposted Sun 26 Mar 17 @ 12:17 pm
